MMOexp-Diablo 4: How to Imprint and Temper Gear for Maximum Potential
Citation de Chunzliu le 19 mars 2026, 01:52Are you looking to upgrade your gear in Diablo 4, whether it's one-star, two-star, three-star, or even four-star equipment, but aren't quite sure where to begin? Or maybe you're just starting out and want to understand how the gear system works in Season 12.
Either way, you've come to the right place Diablo 4 Items. This guide will break down the most efficient ways to acquire gear, from the very start of your character all the way to the highest tiers of endgame content, ensuring you get the most greater AICS gear possible.
We'll cover gear types, stats, aspects, crafting, torments, and the most effective farming routes for both new and veteran players. By the end of this guide, you'll have a clear roadmap for progression and be equipped to maximize your damage, survivability, and endgame potential.
Gear Types in Diablo 4
In Diablo 4, gear comes in several types, each denoted by color and rarity. Understanding the distinctions is crucial for prioritizing what to equip, salvage, or upgrade. Here's a quick breakdown:
1.Common Gear (White)-The basic starting gear. Simple stats and no special bonuses.
2.Magic Gear (Blue)-Slightly stronger than common gear with additional stat lines.
3.Rare Gear (Yellow)-Features multiple stat lines and begins the path toward customization.
4.Ancestral Gear (Orange)-Comes with aspects, which are additional bonuses that can be transferred to other pieces.
5.Unique Gear (Beige)-Rarely found and can include multiple aspects.
6.Greater AICS Gear (Starred Ancestral)-Ancestral gear with a star, giving a 50% increase over the standard AICS at maximum potential.
7.Mythic Unique Gear (Purple)-The pinnacle of Diablo 4 gear, always possessing greater AICS and often game-changing effects.
As you progress, you'll notice that item power scales with level. Early game items might start at 11 item power, whereas level 60 gear will have a minimum of 750 item power. Ancestral gear pushes this to 800 item power, representing the current cap in Season 12.
Understanding Stats and AFFIX Lines
Each gear piece in Diablo 4 has stat lines called aphix lines, which increase at certain breakpoints as you level. For example, a level 10 item will have lower maximum life or damage stats compared to a level 20 equivalent. This makes leveling and upgrading gear essential.
To determine the optimal stats for your character, you can consult build planners, like Mobileics, which offer:
Leveling guides showing the key stats and aspects for early progression.
Endgame planners detailing legendary, unique, and mythic gear setups.
Using these guides will help you understand which aspects to prioritize and how to maximize your character's potential through proper gear selection and crafting.
Aspects: The Heart of Customization
Aspects are unique bonuses found on legendary gear. They can be applied to almost any other piece of gear, regardless of its base type, effectively transforming rare gear into legendary gear by transferring the aspect.
For example:
You find a four-stat yellow piece of gear (rare).
You salvage a legendary pair of pants to collect its aspect.
Applying the aspect converts the yellow pants into a legendary piece, while retaining its four stat lines.
The name of the gear doesn't matter; what counts is the aspect. This mechanic allows for incredible flexibility in building your character to match your preferred stats and playstyle.
Salvaging vs Selling Gear
A common question for new players is whether to salvage or sell gear. The answer is almost always salvage. While selling can net a few hundred thousand gold for unique items, salvaging provides essential crafting materials:
White (common) gear → Rawhide
Magic (blue) gear → More Rawhide + additional crafting mats
Rare (yellow) gear → Veiled Crystals (used for tempering and imprinting)
Legendary (orange) gear → Legendary crafting materials
Greater AICS Legendary gear → Forgotten Souls + Legendary crafting materials
Uniques → Large amounts of Veiled Crystals and Legendary crafting materials
Materials like Veiled Crystals and Forgotten Souls are crucial early on for imprinting aspects and tempering gear to improve stats. Salvaging early and often sets you up for long-term success.
Tempering and Imprinting
Tempering and imprinting allow you to enhance gear further:
Tempering applies bonuses to gear to improve a stat line. Early on, you can temper almost any gear with Veiled Crystals.
Imprinting lets you apply aspects from your Codex of Power onto gear. For example, you could imprint "Numbing Wrath" onto a rare helmet, transforming it into a legendary helmet with that aspect.
Imprinting costs Forgotten Souls for legendary aspects or Veiled Crystals for early-game aspects. Properly managing these materials ensures that your gear progression remains smooth and efficient.Unlocking Torment Tiers
To access the best gear, including ancestral gear, you must unlock Torment Tiers. Here's how:
1.Complete the Hellish Descent dungeon. This unlocks the Pits, which is required for ancestral drops.
2.Start at Pit Number 10. Pit 7 corresponds to Penitent difficulty, which helps gauge if your character is ready.
3.Once Torment 1 is accessible, you can begin farming ancestral gear reliably.
Note: Dying in early Torment Tiers carries no hardcore penalty, so experiment freely to find what you can handle.
Farming Gear: The Best Sources
There are several ways to acquire ancestral, legendary, and mythic gear:
- Grim Favors and Whisper Caches
Found along the map and at boss locations.
Complete these for a chance at high-quality gear, glyphs, and tempering manuals.
Can be done at lower Torment Tiers, while still receiving endgame rewards.
- The Pits
Drops ancestral gear but is not the most efficient farm.
Necessary for glyph progression and early-leveling materials.
- Oles (Murmuring Opals)
Can be gambled at vendors to acquire missing gear pieces.
Has a rare chance to upgrade to mythic quality.
Great for filling your Codex of Power with specific aspects.
- Mercenary Bartering
Level mercenaries to unlock bartering options.
Trade pale marks for salvage materials, gear, and rare aspects.
Offers daily free resets to refresh available items.
- Hell Tides
A seasonal activity with abundant monsters, chests, and loot.
Targeted chest types help focus farming (weapons, jewelry, etc.).
Collect Sigil Powder to craft Nightmare Dungeon Sigils for specific affixes.
- Nightmare Dungeons
Use crafted sigils to access special dungeons.
Focus on: Equipment Delves and Hidden Armories for guaranteed greater AICS drops.
Rare dungeons like Treasure Breach or Prankster offer mythic uniques.
- Unders City (Expansion Required)
Grants guaranteed ancestral legendaries from tributes of Radiance.
Unlock by completing Deeds of a Champion questline.
- Infernal Hordes
Multi-wave dungeons (10, 8, or 6 waves) that reward ether, equipment, and materials.
Always open the equipment chest for guaranteed ancestral gear and Scrolls of Restoration.
- Seasonal Reputation
Earned through seasonal content like Hell Tides, Slaughterhouses, and Bloody Nightmare Dungeons.
Rewards include guaranteed ancestral gear, lair boss keys, and nightmare dungeon keys.
Especially effective for early access to bloodied affixes and seasonal upgrades.
- Bosses
The only reliable method to target-farm specific uniques.
Combine boss loot tables with Mobileics guides to identify which bosses drop the gear you need.
Final Tips for Gear Efficiency
Favorite your best gear: prevents accidental salvaging.
Salvage early and often: ensures access to Veiled Crystals, Legendary Materials, and Forgotten Souls.
Use Codex of Power: track all collected aspects to imprint efficiently.
Follow build planners: choose stats and aspects aligned with your playstyle.
Rotate activities: Hell Tides, Nightmare Dungeons, and Infernal Hordes create a smooth gear loop.
By following these methods, you can progress from common starter gear to mythic uniques, fully optimized for your build.
Whether you're focusing on offense, defense, or utility, there's a clear path to acquiring the strongest gear in Diablo 4 Season 12.
Conclusion cheap Diablo 4 materials
Gear progression in Diablo 4 can feel overwhelming at first, but understanding the mechanics, item types, aspects, and farming sources simplifies the process significantly. From salvaging and imprinting to torments and Nightmare Dungeons, Season 12 offers multiple pathways to reach the pinnacle of item power.
Now it's time to dive into Hell Tides, unlock the Pits, and start collecting your first ancestral gear. Equip, imprint, and temper your way to a fully optimized build, and dominate the world of Sanctuary in Season 12!
For example:
- The Pits
- Hell Tides
- Infernal Hordes
- Bosses
![Un CPC 464 dans Pawn Stars [Angleterre]](/wp-content/uploads/2018/10/Amstrad_CPC_on_Pawn_Stars_UKENG.jpg)
